Here is the list of DIY articles on ClubITR:
General
Painting a rocker cover
DC2
B Series VTEC Valve Clearance Adjustment
Changing Front Brake Pads - DC2R (Article describing a front pad change on a DC2 Integra)
Rear Wheel Bearing Replacement (Article describing rear wheel bearing replacement process)
Rear Trailing Arm bush replacement DC2 (Article describing how to replace rear trailing arm bushes)
Tinkerbell - eBay oil cooler fitted (Article describing the installation of a 19 row oil cooler)
Changing rear brake pads for DC2 (Article describing a rear front pad change on a DC2 Integra)
Changing rear brake rotors for DC2 (Article describing the replacement of rear brake rotors on a DC2 Integra)
Dismantling helical LSD (Article showing how to dismantle, clean and rebuild ITR OEM LSD)
DC5
2005 RSX Front + Rear conversion (Article on how to convert to DC5R to a DC5 Type S)
DC5 Type S HID Installation (Article describing installation of aftermerket HID on DC5)
DC5 Headunit & Speakers (Article descibing audio installation)
ES Motor Mounts Inserts Install (Article describing how to install Motor Mount inserts)
Front Lower Control Arm Bushing Install
Rear Upper Control Arm Bushing Install
FN2
DIY: FN2 CTR Speaker Installation - front & rear (Article descibing audio installation)
General
DC2
DC5
FN2
