hey mate nice write up , very clean dc2r. did that rust occur due to salt on winter roads or is it a normal thing for dc2s to rust there ? any other rust spots that you know of?
my dc2 1999 project tidy
It's more common in the US and Europe due to the conditions they go through year round.Originally posted by KEVSY View Posthey mate nice write up , very clean dc2r. did that rust occur due to salt on winter roads or is it a normal thing for dc2s to rust there ? any other rust spots that you know of?
Salty roads during the winter and the wet months they have are the cause.
Cars in Califronia and Aus tend to last longer without rust due to our drier salt free climate.
So not really a problem for our cars./Oo ___H___ oO\
|=_/_______\_=|
thanks kavehman was dreading the thought i pulling my car apart.Originally posted by kavehman View PostIt's more common in the US and Europe due to the conditions they go through year round.
this is a problem for ALL integras but will be less of a problem in the warmer countrys like mentioned,The problem is honads desighn of the sill at the back of the sill they have left a small slit hich allows water to gain entry into the sill its sits there and slowly rots the rear quarter out from the inside out!!
so rust can be very bad with very little notice from the outside my rear quarters look perfect from the outside and have no rust on the car anywhere else but as u can see from the pics the dreaded rear sill slit problem had started but this should be fixed now and shall be filling up the slits this weekend.hope this helps a little.
cheers for the feedback is nice to have some incouragement whilist doing these things will be cecking out everyone elses rides too.
well after doing the front strut bar ends and liking the result 8) felt like it was time to do some more sprayin so decided to remove the rear bar in the boot which weighed about! 3000000 stone!! :lol: :lol: does this do alot for body rigidity or can it be removed with not much loss to handiling? just think it weighs soooo much would be better without for weight loss or even a lighter aftermarket product are these available or? anyways after a small gym style montage training session i removed the rear bar. :lol:
found this:
and thats the only excuse i needed! :lol: :lol:
so began the sandown of the bar and wow they like to put thick paint on that bar i can tell ya!!
all sanded down :
is quite hard to see the finished sanding due to the fact the bar was silver in the first place but removed all paint and cleaned off any residue ready for painting.so strung the bar up with the help of a 20 ton chain and a car as a counter weight!! :lol: :lol: and began the priming process.
as you can see the garage is lovely and clear and clean!!!!!:lol: the car is more worthy of my time at the moment!! 8) shall not be saying that to my missus though would like to keep my undercarriage thanks! :lol: :lol:
all sprayed and finished:
and now installed:
i think it looks loads better than the silver it really stuck out when u opened the boot and now looks real suttle and blends in real nice with the colours of the boot i think it looks more oem than it was before if u know what i mean! :? :shock: :lol:
so i now have a stealthy heavy as hell piece of metal in the boot!! :lol: :lol: 8)
what u think?
usdm dc2r seems to be a much softer version. They have an ugly steering wheel and the seats are completely different, because most americans are over weight and they like comfortable cars, hence the center arm rest too.
hitting vtec is like masturbating, sometimes you just do it because you can
hahahaha yep gotta agree the americans would be way to big for the recaro seats! didnt realise they got different seats in there version though! i bet with that compression ratio they must feel alot different,america really did get screwed there makes a change them getting screwed over and not them screwing other people over
so as stated earlier when i was under the car for a little inspection i noticed the front driverside gearbox torque mount was perished so ordered some new parts:
so got the car on the ramps and got to work.
so heres the mount in question:
as u can see in this pic the rubber is actually ripping!
glad i got this done sooner than better!!:
So i took the weight off the mounts via a rather large axle stand looking weight holder!
(not sure of the proper name!),so i then removed the two plastic mounting screws for the plastic guarding underneath the bumper for ease of access to everything as pictured below:
before:
after:
This gave me alot better access to the brackets and bolts that i needed to get to with the tools required.
This is the bracket that is bolted onto the engine via three long bolts:
A few mins later and some sweet arm pumping! i got to this stage:
i removed these bolts with my fingers and loosened the bottom bolt off a bit so it gave the mounting bracket alittle space between itslef and the bolt.
gonna sort it in the next week if i can get round to it!
