Originally posted by M@lew
View Post
Re the c pillar that bar is mostly in compression or tension depending on the chassis movement, a harness passing over it will want to shear on the connection which is something it was not designed for, i wouldn't want to put it there purely for angle correction
Dave on your second eye bolt near the quarter panel, if you can try and tighten it more so it makes a straight line pointing toward the front of the car, its only a minor thing but a strong pull on the harness can make it turn around and cause a bit if slack to form, keep up the good work and boo you for not getting a powergetter
