After running the mugen n1 ecu for about a month n abit now
I'm looking in upgrading my stock valve springs because it recommends to change valve spring to use with the ecu. At the moment, i'm got a few in mind, JUN, Spoon, Mugen and Toda. Do valve springs have different specs? or do they all do the same job and able to support the engine to rev to 9200rpm safely?
I'm planning to get cams later on as well, is it better to stick with the same brand with the valve springs? What is a good set of cams to look at?
