I have 2 torn engine mounts and was wondering are engine mount inserts a "quick fix" for torn engine mounts. Will it be as good as new? Energy suspension sells the inserts for around 75 bucks whereas a new set of engine mounts are 500ish.
Engine mount inserts
althought once torn i personally would not recommend just having inserts..
i would say either replace them or you could do a "repair" diy filling it with polyurathane.. that does work..
heres a link to a DIY Mugsee and I did
http://forum.clubitr.com.au/showthread.php?t=2537Memorable quotes
Originally posted by Q_ballsome say, his vtec was switched off on his last 4 outings at wakefield....
all we know is hes called The Perry!!A wise man once said "Tok like Gay better than been like gay"Originally posted by tinkerbellif those HA's are 7k old - i will eat my own arsehole...
Originally posted by WayneNever again complain about a honda's reliability just be glad you dont own an Alfa
mount inserts will generate a huge amount of vibrations to the whole car (my one does anyway). i have the energy suspension inserts in my car and i dont recommend it unless u dont mind the vibrations on low revs. on the other hand it did made my car feel abit more responsive.
i would say save up to get a new set of mounts, but if u dont have the cash or want to do a DIY then use the inserts till u can get new mounts.
stock mounts r too soft, thus why they break so easily. but they do provide a comfortable ride.
from wot i have read and opinions from other ppl, Mugen mounts are good quality and still keeping as close as to stock mount specs, 20% more stiffer then stock is wot i've heard (correct me if im wrong).
except you get mugen mounts....any aftermarket mounts will give you similar vibrations same as insert did.....so if you are on a budget....either one is good....you still end up paying the same labour fee unless you DIY......Mugen Whore #2
ヒール&トウのやりかた
1)ブレーキを踏む
2)クラッチを切る
3)シフトダウンしなから、
アクセルをぶかす
4)クラッチをつなぐ
:blah:
if your on a really tight budget do the repair..
usually only one mount tears at a time.. most likely the rear.
you can just replace the rear or take out the rear and poly it and put it back in.
you dont have to replace all 4 of your mounts most replacement mounts for all of them cost a fair bit even OEM honda ones..
not a fan of the mugen mounts.. i rather live with the insane vibration caused by stiffer aftermarket ones =P..Memorable quotes
Not sure for DC5s.... But on the DC2, the header has a lower bracket so it doesn't stress the welds where it it bolted to the manifold as much. However, there is no flex-pipe in the system so the flex has to be taken up in the join between the header and the cat.Originally posted by black_dc_5 View PostI heard / read it somewhere running with broken mounts could crack / damage ur header. Is that true?
Either way, any additional movement caused by a broken engine mount certainly isn't a good thing...
ehh did u not read my post..Originally posted by c01567 View PostIs it recommended to do all the mounts at once instead of just replacing the broken ones?
you can just replace the broken ones.
but if you wanna splurge.. or have reason to replace all of them it be your installing harsher mounts and not just replacing them with OEM..
if your using OEM might as well just replace the broken onesMemorable quotes
