DC5 oil plugs !
    DC5 oil plugs !
    Hey guys, I just have a noob question. I frequently change my cars oil and have realised how hard it is to take off the drain and fill plugs.. Any tips with taking them off ? Especially the fill plug for the transmission oil.. Its like a trying to move a mountain.
    This belongs in the General Automotive section bud!
    What do you usually use or do when taking them off? A breaker bar?
      Use the correct washer so you dont get corrosion. Also if u do it superman tight expect it to be hard to take back off
        Sorry Shak !
        I usually just use a socket set. It's quite hard to use anything near the gearbox area..
        @Karl
        Dam.. Should have changed the washers. Any ideas what to do now ?
          Check out the Honda recommended torque setting on the sump plug - they're not meant to be done up very tight so you shouldn't have problems undoing them if you do it up to spec.
            Yep, and if you use a new washer each time you'll have no problems getting them undone.
              Thanks guys.. Any ideas how to loosen them in their current state ?
                WD40 and a breaker bar mate.
                  Get a breaker bar with a long extension arm or a pipe to slide onto the end of it to increase your turning force. Once it's loosened, switch over to a socket wrench.
                  CW DC5R Build
                    Thanks Jaz and Krob. Problem is.. the bolt is kind of screwed as the constant twist has shave bits of the bolt off. I am screwed..
                      Which plug are you trying to get out?
                      If it is the engine sump bolt, you could use a hammer and chisel to get the bolt to crack
                      Ph: +61397947767
                        Oh deer, how did you round off the bolt ?!!!?!?!??!
                        www.gundamuniverse.com.au
                          Its the transmission fill plug....
                          I was just trying to turning it with a lot of force and it kept slipping.. Ended up round the bolt. Not entirely but pretty bad.
                            Are you using the right point socket? If not, get the 6 point socket and if it's the plug's semi-okay it should come loose
                            If it's shagged, get a vice grip on it (should be enough room to go from below), and a hammer tap should set it loose.
                              if its rounded off. hammer on a slightly to small imperial socket.
