Weird electrical problem
    Hey guys, my brother has just purchased a dc2 integra and we've encounterd a problem.
    Whenever we hit the brakes, all interior lights (cluster, controls..) turn on, also the Parker lights light up as well, when were off the brakes the lights turn off and it's fine again, has anyone encountered a problem like this?
    S2000 TRACK/DAILY BUILD
    Best to just take it to an electrician
    BNR34 Build [SOLD]
    APB DC5R Build [SOLD]
    NSEX
      This may sound stupid but i had this same problem in an old swift i had... Check the brake and headlight globes... Sometimes the hi and low beam brake/headlight light blow then fuse together across eachother... Which then in turn causes your cluster lights to come on..... In my case it turned out being the brake globe....
      Hope that makes sense lol....
        if you read the post, he asked if anyone had experienced it, not "what should i do"
          Yep check for faulty globes 1st.
          Then if thats a no go. next question id ask is do you have a alarm. the alarm may be hooked up to you parkers and brakes. so they flash when your alarm goes off. The diode that stops back feed may be stuffed.
            Yeah I do I have an alarm, but tomorrow ill change the rear globes to see if that helps, ill update when I do it, thanks for the replies guys..
