Idling temperamental.. It will rev at 700 rpm when warm.. If i press the brake it will drop below 500 rpm and same if i rotate the steering wheel all the way. It does correct it self after a second or so. If air con's turned on it will rev low for a sec then about 1100 rpm..
If im driving around 70 km/h and fully press clutch in it will drop to about 500 rpm then correct it self. Finding i have to ride the clutch and rev about 2500 rpm to take off in 1st gear or is will nearly stall...
Also wasn't doin this before so 100% sure not my driving...
The iacv has been cleaned and fuel injecter cleaner has been used. I run it on 98% octane...
Any idea guys.. Im also running a ram intake to the stock box with a K&N filter. Would that cause this??
Any help would be great guys Thanks???
