A little noob in this department and need your guys help with a few questions
Mods are suspension and cai, with stock exhaust. i'm looking at getting the clubrsx racing header with the angled cel and spring bolts, welded with high flow cat.
1. If i install the header and cat first, is there going to be any install problem if I later swap out the entire catback exhaust? Will they have to cut into anything? Was looking at the Fuji powergetter.
2. Any cat recommendations?
3. Is it necessary to get ESMMs or motor mounts? Don't have the money for MM's atm so was gonna settle for the inserts, but i hear the vibrations are almost unbearable. Or is there another option available? if i get the cat welded with a flex pipe, will it be enough to reduce strain on the header?
4. Is there anything else i need to complete my setup?
I've been lurking here for a while but now I need help
Cheers.
Cheers.
