VIDEO -- http://www.youtube.com/watch?v=l4cVq_k32Eo
Ok so i used to occasionally get this tapping noise at all rpms (couldnt hear above vtec due to noise of exhaust/intake) but definitely below and at least up to vtec... It is a singly tick tick tick tick noise and sounds like a tappet type noise... Sometimes if i just gassed it the noise would disappear. Well, now its here for good..
Now -- I originally thought LMA but some other causes I've heard of are:
Scored Cylinder Wall / Low Oil (Possible, has happened once or twice and she is drinking a bit of oil at the moment kinda unexplainably).
Timing Belt Tensioner? Not sure how ...
LMA's - Obvious but never heard one so cant compare.
Bottom end knock (sounds like its coming from the head though)..
The engine DID run QUITE low on oil once but was fine afterwards and when the light came on I stopped driving and topped up the oil.. The noise started after a high rpm (say, 9000rpm) second into third shift and hasn't gone away since.. Power seems to be ok, fuel economy is ok ... Just getting this bloody horrible noise!
Hoping its something easy to fix -- I can't rebuild at the moment, just did the bloody gearbox!
Everyone kinda think just check all the obvious things (any i havent listed id be happy to check, let me know) and if a bottom end issue or scored cylinder wall then drive it till she drives no more?
Thanks guys ... I lover her, but she costs so much damn money.
Oh and its done about 115,000kms ... And I'm about to change the timing belt.. Valve lash hasnt been adjusted in 30,000kms or so..
-- haven't adjusted anything yet. Just started it to record the sound it was making. Haven't had time to adjust anything yet !!
