Hey guys, im going to install a dvd player head unit very soon. I want to install that switch that can make the movies run while the car is moving, and also on, only when the hand brake is pulled up, does someone mind telling me what parts are needed, and instructions if possible?
DVD player headunit, switch to have it on all the time and on only when e-brake is up
is all depends what deck u got man...on the clarion decks u just earth the trigger out and it allows u to watch dvds while driving and some decks u connect the trigger to power antennaOriginally posted by plAythiNG View PostHey guys, im going to install a dvd player head unit very soon. I want to install that switch that can make the movies run while the car is moving, and also on, only when the hand brake is pulled up, does someone mind telling me what parts are needed, and instructions if possible?
Yeah my old clarion one you just had to earth it.. It was a TV/DVD ect. Get over that shit pretty quick... Glad I never installed it in the R... But yeah any deck you get will be easy peasy to by pass that unwanted feature..
Quote:
JHDM-B18C7 >>>>> Source Code: DC2R 00-0016
SOLD
Look at the wires connected to the back of your dvd player,find the cable thats meant to connect the handbrake,it should have tags on them if your not sure read your instruction manual,then simply ground it which means wire it to anything metal i.e a metal bracket behind the deck somewhere.And it will work fine.
All a handbrake does is act as a grounder when its fully up and doesnt ground when its down.
In addition to that if you want to add a switch,simply buy a switch from super cheap auto or sumwhere similar and depending where you want your switch connect it,you will need to lengthen your e-brake wire aswell.The switch goes anywhere along the e-brake wire,when its off it cuts off the connection and when its on it will be fully connected,kinda like how a fuse works,if its not in the item wont work but when its in it works.Last edited by Dkonect; 14-04-10, 05:39 PM.
true my top of the line clarion dvd deck can just be earthed...but the cheaper ones cant be .. u have to connect them to the electrical aeriel! they must need some sort of signal or somethin :SOriginally posted by DrTran View PostI ususally just ground or put a positive wire to it and call it a day. It all really depends on your head unit. Some units you can just ground some you have to add stuff.
