I have searched this topic to no avail. Can anyone please tell me the factory standard wheel alignment settings for a 98 spec dc2r.
DC2R stock wheel alignment setting
Um...I got a question.
Wasn't too long ago I had to replaced my bald tires so nevertheless I did so. Obviously I had to get a wheel alignment and I found table very similar to the one above in the manual. My question is; when getting the wheel alignment done, do I let the people at the tyre place follow the settings stated in the manual or pre-set setting from their computer? My DC5R is stock btw
I've always suspected the handling wasn't as good as before and I thought maybe the setting they used are incorrect.
Thanks
its is possible but very unlikly that your car handles worse after the wheel alignment. Every car should have a wheel alignment at least once a year as setting do inevitably change due to wear on steering componant and bushes and even tyres.
hitting vtec is like masturbating, sometimes you just do it because you can
