Since no one has bothered to take photos of this i decided to do so for refence...
Took the front door off to take a look inside at the speaker (as it buzzes a little when i crank it on a bassy song).
Took some measurements as you can see on the photos.
I want to fit some 6.5" Hertz speakers (or some 6x9s if possible??).. looks like a spacer will need to be made due to the size.. 6" Vs 6.5". (or are the stock ones 5")????
the distance between the glass and the face of the sheet metal on which the space sits is about 5.5cm
the distance from the centre of the hole/speakers to the mounting holes in the sheet metal for the spacer is 9cm
orig speakers are 5.5cm deep in total
what are the two black boxes inside the door trim. one of which would obstruct a 6x9 being put in...
So question is..
6x9+lots of effort getting it in, making the right size spacer, removing that black box that is in the way and getting hertz ECX690
OR
6.5"+less effort, right size spacer but at least its round, hertz HCX165
OR focal?
30W max and 15W nominal. I assume RMS
So question is..
OR
OR focal?
