Extra Hissing with Headers
    I bought my maximworks extractors about 3-4months ago and noticed that there was a hissing sound (like water running through the pipes).
    I was told by my mechanic even before he intalled that it would make this sound so i was not worried about that.
    But recently it has also started to whistle a little all of a sudden. It is not very loud but you can still hear it when it happens.
    Anybody know what the problem may be if any???
    BTW i drive a DC2R if that helps???
    Normal especially with MaximWorks manifolds ... Part and parcel of running a larger pipe sized exhaust manifold with flex joints.
    Confirm there isn't an exhaust/manifold leak however. Sound can be attributed by something else.
      its normal...i had the same sound on my mugen header
      z10 says:
      z10 says:
        btw what are they like? can you do a review of them? szymonsta is getting them soon.. i want feedback about them... whats the bum dyno say? what headers did you have before that?
          I have the same hissing sound on my Toda headers too.
            after i installed my mugen headers on my em1 i had the hissing sound as well.
            found out there was a leak between the welds. got it fixed up and the hissing sound was gone!
              00dc2 .. i'll b able to tell u in two weeks when they get installed!
              noel..m-bit dc2r header does not have 'flex joints'.
                isnt it the scavenging effects of the header ?
                  say what?
                    man i gotta see these puppies before they go in...
                    baffled sum goes in tuesday
                      Get a mate to block your exhaust tip while you listen if the hissing gets louder. If it does you know you have a exhaust leak.
                        block the exhaust tip...? err.... i dunno if thats a good idea.... and with what anyways..?
                          Szy - Yes ... I know ... Should've word it better. Flex joint MaximWorks exhaust manifolds have a more distinct hissing sound/noise to most.
                            my DC5R hisses pretty much exactly at 3000rpm...
                            www.belgarage.com.au
