Well, after months of putting up with the ridiculous rear view in the FN2, I’ve decided to install ultrasonic parking sensors.
You will need:
- Parking sensor kit
- Screwdrivers (flat + phillips heads)
- 10mm socket
- 14mm socket
- trim removal tools (not essential, but does make it easier)
Start by removing the four blanking covers around the boot that cover 10mm bolts. Then remove these bolts.
Remove the four push/retainer clips from under the rear bumper. Remove the ones on either end of the bumper, and the two closes to the middle. The two clips directly under each exhaust tip is there to hold the exhaust trim in place. You do not need to remove those clips to take off the bumper.
Remove the screw on the fender trim. It’s a tight fit so be careful not to strip the head. Use a #1 phillips screwdriver. Once the screw is out, you can pull away the fender trim from the body.
Start at the bottom and work your way up. You will need to use a bit of force, but slide your hand up the trim once a clip has come out. Do not just yank on the trim from the bottom or you will break these clips. Pull the trim off until you can see the edge of the rear bumper. Put a cloth or something in the gap to stop it from closing in.
You will then need to remove one Phillips head screw and one clip from each side that lie under the fender trim.
You will need:
- 10mm socket
- 14mm socket
