So I got a wheel alignment done after getting the stock settings of camber, toe, etc. I told them my car was veering left (more than normal).
Printed out settings and I have too much negative camber on the driver's side both front and rear. He said this will cause my car to veer left.
The setting is -1°29' front and -1°24' rear.
The left side is ok at -0°32' and -0°52'.
First question is, how did my right side camber become like that as compared to my left side?
Second question... he said he can install a camber adjuster for me for the front driver's side only, and quoted me $229 installed with 'free' wheel alignment.
Should I be taking it there to get one side installed only, or should I buy a known camber kit that you guys use and get left and right side as well as front and rear? What kits do you recommend, how much are they, and who can install it?
. If you are concerned about tyre wear set toe to zero.
