JDM DC5R Cams into AUDM DC5R
    Can you use the JDM DC5R K20A cams ( I & E) in the AUDM DC5R K20A using stock valve train ( springs , retainers etc) ?
    Will be using Kpro of course with this.
    I think you can. Just that you won't be able to rev it more as AUDM valve not as stiff as JDM. Although one side is actually the same as JDM, can't remember the Intk. side or the Exhst. side
      No point doing this Chi as with that money and little more you can get some aftermarket cams which would give you better bang for the buck.
      Unless the king of cheapness pulls off another stunt
        Yes I have done this with no problems.
