I know the short type oil filter increases oil pressure but what is the benefit oof high oil pressure. i have dc5s with a k20z. Also with oil, i looked at the manual and the best one for aussie temps is 15w 40, but ive seen others on the forums using 15w 50 and they its better but this one is not even on the manual.
short vs long oil filter
Prash Imaging (Facebook) - Please like!
Flickr
my car blog - Have a read
my 2nd car blog - Have a read tooTags: None
Originally posted by crashprash View PostI know the short type oil filter increases oil pressure but what is the benefit oof high oil pressure. i have dc5s with a k20z. Also with oil, i looked at the manual and the best one for aussie temps is 15w 40, but ive seen others on the forums using 15w 50 and they its better but this one is not even on the manual.
can you clarify what you are talking about?... retired/
To answer the original poster, I would stick to the recommended grade from honda for your usage and temperatures. Eg. I use 10-30 in the winter and 10-40 in the summer living in Melbourne and Tas.
I have no experience with using a different filter to the stock honda ones you get frmo any dealer. They have not failed me for many kms and quite a few track days.
Originally posted by VTECMACHINE View PostMore oil pressure = more oil = More lubrication = less piston friction = more response and power.
15W- 50 opposed to 15W-40 means that the oil can withstand higher temps before it starts to break down.. Blanket statements about oil pressure like that are scary, it would be more correct to say that more pressure at the pressure sensor after the oil filter suggests that there has been less pressure drop over the filter media which means more flow, which is good
but not at the expense of filtration.
The temperature at which an oil breaks down is more a factor of the chemistry of the oil than its designed viscosity. Eg. a 10-30 synthetic oil could take a higher temperature before the viscosity begins to decrease considerably from its designed SAE 30 viscosity whereas a mineral 20-50 could get to 100 degrees and thin out considerably or evaporate a significant amount.
The only thing you can definitely say about a 15-50 over a 15-40 is that it will probably be thicker at 100 degrees resulting in more pressure and less flow at this temperature, although the ranges of allowable viscosity for oils are quite large so it is easy for a thick W40 oil to be similar to a thin W50.
Originally posted by ChargeR View PostI have no experience with using a different filter to the stock honda ones you get frmo any dealer.
full details are actually here:
http://www.ozhonda.com/forum/showthr...highlight=z79a... retired/
Originally posted by ChargeR View PostBoth of these statements are possibly untrue. Blanket statements about oil pressure like that are scary, it would be more correct to say that more pressure at the pressure sensor after the oil filter suggests that there has been less pressure drop over the filter media which means more flow, which is good
The only thing you can definitely say about a 15-50 over a 15-40 is that it will probably be thicker at 100 degrees resulting in more pressure and less flow at this temperature, although the ranges of allowable viscosity for oils are quite large so it is easy for a thick W40 oil to be similar to a thin W50.... retired/
after fitting a oil sandwich plate for sensors should i change to a short type filter for more pressure or stick to the standard one?Prash Imaging (Facebook) - Please like!
Flickr
I think Adrian @ Toda posted a while back about how thinner, higher quality oils can increase power output but only by 5% at maximum (from memory, i could be wrong).
in regards to the OP, i would take what chargr says on board as he seems like he knows what he's on aboutsigpicCurrent holder of the Win folder.
Originally posted by crashprash View Postafter fitting a oil sandwich plate for sensors should i change to a short type filter for more pressure or stick to the standard one?
Listen to Didz he also sometimes knows what he is on about.
