Spoon front strut bars ?
    wanna get a spoon front strut bars for my dc5r but don't know the OEM one can stay?
    Thz
    Yes it can
    Vivid Blue Integra Type-S
      thz~~
        yes oem chasis brace can stay with spoon strut bar,
        I have em on atm.
          how much did u get for a new one?
            they retail for 250 each.
            try jdm yard for them.
              Yes, What this sexually frustrated person just said.
                will the spoon front strut bars clear my guppe m air box?
                thanz
                  Yes it will clear. i used to have the spoon front strut bar fitted with gruppem intake, no problem with the clearance issues. You may want to put some cushion tape between the strut bar and gruppem box to avoid vibrations between them at high revs.
                    um......actually spoon or mugen, which one is better?
                      Mugen.
                      Its spot welded and doesn't have weak bolt points like the spoon one.
                      But it does cost a fair bit more.
                        i have the mugen one and had tried the spoon one too. I felt that the mugen is slightly stiffer. Personally prefer the spoon one although its slightly softer =p
                          thz...how about the rear one then?
                            Rear mugen strut bar is awesome, But you'll need to cut a bit of your rear plastic trim, You can also double up.
                              Mugen rear strut doesnt actually go along your normal strut tops/shocks.
                              IT goes along behind the rear seats connecting the chasis .
                              So u can use a Mugen Rear strut bar along with Another Brand strut bar, i would recommend carbing.
