If the Prelude wheel is +55, and the AUDM DC5R wheel is +42, then you will be increasing the track by 26mm ((55 - 42) * 2 = 26mm) . ie. the wheels will stick out 13mm further on each side.
This will affect your scrub radius etc, and may promote a bit of "tramlining".
They might fit but the car might not feel as nice to drive.
at the moment, the car has 17's on it with low profiles and i hate the way it drives. im looking at getting CW DC5R rims or jsut go back to stock rims but im more keen to get teh type R rims on there.
Aussie Spec DC5 Wheels will fit onto Preludes no worries, there's nothing to be concerned about.
The car won't feel as good as it will on wheels with the correct offset.
That may not concern you, but it would concern me.
Kind of like saying "JDM DC5R wheels fit AuDM DC5R's just fine" .... which they do, but the reduction in track due to the incorrect offset causes some 'interesting' handling traits.
