squeeking noise
    squeeking noise
    Now before anyone flames i've tried looking through previous posts.
    Okay now when the previous owner was in possession of the dc2r the interior was stripped out. I didnt notice any squeeking noises, etc. I asked him to put the interior back in and all was good. It's been nearly a month since i've owned the car and i've just noticed it starts to squeek but only when im going over bumps, etc. The only thing i could think of either is that the interior is not fitted back in properly, the mounts of the coilovers/struts are rubbing against the chassis. I'm currently have BuddyClub N+ on the teg and an exhaust if that helps. I know the car is a very raw car with no sound deadening, etc.
    My mate also has a dc2r with coilovers and i've never noticed a squeeking noise at all. Nothing else that could come to my attention. I've had coilovers on my previous car and i've never had any squeeking noises. Do you guys who have aftermarket suspension setups get this squeeking sound ? Could anyone suggest it to be anything else?
    Cheers
    brake pad and rotor? just an idea...
    Mugen Whore #2
    ヒール&トウのやりかた
    1)ブレーキを踏む
    2)クラッチを切る
    3)シフトダウンしなから、
      アクセルをぶかす
    4)クラッチをつなぐ
    :blah:
      my rear bumper squeeks...
        try to locate exactly where the noise is coming from..interier or exterior. if its interior, this may sound stupid but i had a squeeking noise as well and thought it was the interior plastic rubbing on something..after a while i realised it was the seatbelt lock (the part the seatbelt plugs into)...bit of WD40 and your set... just an idea..
          mine did to after i put back all the nuts and bolts and its all good now.
          Team Misplaced CT9A Owner #009
            it only happens when im going over bumps... never really noticed it until i played around with the dampening settings.
