Hi guys,
I need some advice here as I've discovered a leak with my ep3. I done my clutch about 1 month ago with a workshop but when i first spotted the wet patch I was dreading myself that it maybe the rear main seal not being installed properly by my mechanic. My car never had a leak (Apart from some slow seepage through the valve cover and front crank seal) before until this.
So I've undone the clutch cover plate to get a peak and found that the engine side looks dry but if peer into the side facing the gearbox, i can see some wet patches. This leads me to suspect that I'm leaking transmission oil from the input shaft rather than the rear main seal.
I did recall my mechanic fill the transmission oil from the speedo sensor hole, and not sure if overfilling may cause this.
I've checked the driveshafts area, looks relatively dry aside the gap from the bellhousing
Nothing came out of the breather. Took the rubber bit out to look underneath it, it's a bit moist but i assume that's just normal. Wiped down the oil patch and see how fast it would come back.
Went back to the workshop for a look as the oil leaks at the bottom has returned after 3hours of driving. This time they looked a bit further and they've suspect it might be valve cover gasket as there is a bit of seepage from the back.
However it's not overwhelmingly obvious because the seepage does not look wet enough to suggest it is the primary source of leak such that it seeped through the mating surface between the engine block and transmission bellhousing. The valve cover gasket is not ruled out since the mechanic suggest it may also be possible that over time that the seepage will lead to a build up of oil down below due the gravity.
So he's sprayed brake cleaner on the back of the engine block and will have to see if the leak is visible on both areas, rear of valve cover and bottom of the transmission bell housing.
Has anyone seen this issue before?
Another guy in the UK has the almost the same problem description as me
http://type-r-owners.co.uk/forums/sh...highlight=leak
but the poor guy didn't get any replies.
