This may be a noob question and all but how compatible is say a prb kpro that was fitted to a type s with the converter and wideband .he then sold just k pro unit. ....that unit would then fit on any dc5 r , ep3r kseries correct.. iv heard all k pros r the same just depending on the ecu unit there installed in but iv also heard of reverse lock outs ...anyone shead some light .as iv researched with not much ....
Compatibility of hondata k pro
According to Hondata:
Originally posted by HondataHondata makes hardware modifications to the 2002-2004 ECU enable it to work with the different sensors and actuators found on the 2005-2006 ECU. After these modifications the ECU will not function correctly on a 2002-2004 RSX.
Originally posted by JUST VTEC View PostThank you ChargeR .. so what is the reverse lockout feature ?
pushes a select lock cam into the locked position. As a result, the select lever cannot rotate to the reverse select
position making it impossible to engage reverse gear. At a vehicle speed of 9 mph (15 km/h) or less, the signal from
the ECM is interrupted which turns off the reverse lockout solenoid. The select lock return spring pulls back the select
lock cam enabling the select lever to move freely so the reverse gear can be selected once again.Just going for a drive~146.4kw~
Can anyone clarify if the function of the reverse lock out also prevents the "crunch" noise when trying to select reverse whilst traveling at speed? Re: traveling >20km/h
In my experience, I have accidentally changed from 5th gear into the Reverse gear, however upon engaging reverse gear, there was a loud, high pitched crunch. (traveling at 100km/h)
This experience has left me baffled if that is the normal symptoms of a functioning Reverse Lock out. I'm under the impression that it didn't work, as we're not supposed to crunch the gearbox and that its mechanically impossible to engage Reverse gear whilst traveling forward? (Can a gearbox even select reverse if the counter shafts are spinning in reverse directions?)
Has anyone else utilised their "reverse lock out" function? What happened when you tried? Was there the same noise?
*side note: i'm using a EP3R ECU WITH KPRO using Y2M3 (AUDM K20A2) Gearbox*
If you had of selected reverse @ 100km/h you would have blown reverse gear nicelySleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
Before I went to my haltec ecu the reverse gear would kick in above 20kmh and not allow me to throw the shifter in the reverse area at all. It would create a barrier lets say not allowing you to move into the line to the right of 5/6. Now that I have the haltec I have the same issue as you. I no longer have that little barrier and can go into the reverse area and if I pull down it grinds away as you want to place the gear that runs opposite to the current motion.Just going for a drive~146.4kw~
Originally posted by Batchy View PostBefore I went to my haltec ecu the reverse gear would kick in above 20kmh and not allow me to throw the shifter in the reverse area at all. It would create a barrier lets say not allowing you to move into the line to the right of 5/6. Now that I have the haltec I have the same issue as you. I no longer have that little barrier and can go into the reverse area and if I pull down it grinds away as you want to place the gear that runs opposite to the current motion.
Originally posted by DaRKNT View PostI just tested reverse lockout. It is active and functional on my haltech. Just an FYI.
Cheers darknt.
All good butters.Just going for a drive~146.4kw~
