Ok guys my exhaust on my dc5 sits really low and scrapes over 90% of speed bumps. Other than raising my car to make it not scrape, are there any other things that can be done?
Exhaust scraping help
Hahah yehh but I've herd of people modifying the b-pipe or something like that. That scrape noise kills meOriginally posted by knobosaurus View PostAfraid not. If you're not raising the height, the b pipe will scrape. Many lowered dc5r exhausts end up with flattened b sections.
You can try going to an exhaust shop and see if they can modify your b-pipe to be more flat against the chassis. But it could ruin your air flow.Into Gundam and Anime?! Check out my business at www.facebook.com/officialgundamuniverse
www.gundamuniverse.com.au
The exhaust hanger that holds the b-pipe up can sometimes be responsible for a low hanging exhaust.
I use to remove that exhaust hanger and zip tie the b-pipe up to the chasis for a bit more clearance, and adjusted the rear hangers if required to compensate for the way it now sat. It worked for me, may not for you.Official ClubITR Sponsor: www.autosphere.com.au - For all your maintenance, oils and track needs.
you can get metal cable tires. or cheaper a hose clamp!..Originally posted by DaRKNT View PostMichael, just out of curiosity, how did the zip ties hold up with the heat? Were you constantly replacing them?sigpic
The larger plastic ones held up fine. The smaller ones won't hold the exhaust up and will break easily.
As Karl said though, metal ones would be perfect.Official ClubITR Sponsor: www.autosphere.com.au - For all your maintenance, oils and track needs.
