Body: DC5R 03
Question or problem:
1. Clutch pedal has no resistance.
2. Car does not recgonise key
Modifications
1. I have attempted to bleed the clutch as per diagram below in the 02-06 RSX manual, however have come across the difficulty as there is no pressure/resistance in the pedal when i'm bleeding it. There was very minor fluid coming out, however ceased as we couldn't build up pressure in the clutch master cylinder. There are no visible leaks inside the pedal area and the CMC was working fine before I stripped the car. What can I do? Should I consider removing the CMC and replacing it?
2. I've de-activated the immobiliser through Kpro, however because the car won't even start, the Kpro manager does not even pick it up. Has these happened to anyone before? And is the only solution to take it to Honda for reprogramming?
Norm
Modifications
- Aftermarket Alarm
- Car has been stripped and re-assembled
- Kpro
- No aftermarket clutch master cylinder, and clutch master cylinder and slave was working fine before dissemble.
Norm
