Does the 06 type S have the k20a?
2006 integra type S engine
Originally posted by tinkerbell View Postit is called a K20Z1 or something but is same as K20A...
K20A
+ Displacement: 1998 cc
+ Compression: 11.5:1
+ Power: 220 hp (162 kW) @ 8000 rpm
+ Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
+ Redline: 8500 rpm
K20Z1
+ Compression: 11.0:1
+ Power: 201 hp (150 kW) @ 7800 rpm (sae NET Rev 8/04)
+ Torque: 140 ft·lbf (194 N·m) @ 7000 rpm (sae NET Rev 8/04)
+ Redline: 8400 rpmalmost JDM spec, y0!
for most intents and purposes, they are the "same engine" sang...
like a B18C2 is the "same engine" as B18C7...
but you are 100% right - there are many internal differences...
just like the differences between the K20A and K20A2...Last edited by tinkerbell; 10-01-07, 09:25 PM.... retired/
ok sure. i get what u mean now. but i just wanted to make sure we weren't misleading people. when the question was asked i took it to question whether the type s had the jdm type r engine. if you're familar with dc5's and the k series, then the difference is important to youalmost JDM spec, y0!
