Well PLM headers arrived, tried installing it and i can't get the darn thing on. There is so little room to work with, i unbolted the stock headers and was able to remove the downpipe and cat from the bottom, but there was no way i could remove the top part unless I removed the valve cover; so i took the cover off and was able to pull the stock one out, and even then it was hard to get it out.
Then came installing the new headers, It just wont go in at all... putting it from the engine bay did not fit since there is so little room from the engine and the firewall and from the bottom it is blocked by the swaybar and the trailing arm, mechanic said they may need to drop the subframe... looked at a few diys but they're all on the DC5 which seem so easy as they were able to just slip it from the engine bay.
Guys with ep3s how did you install headers on the car? Also anyone know any good exhaust shops around south or westside brisbane?
