Hi all, just wondering if anyone can point me in the right direction in regards to increasing fuel pressure on my integra.
my current fuel setup is standard, with rdx 410 cc injectors running on e85.
I am seeing 92% injector duty cycle at 7400 rpm, and thats where my power falls off due to the standard PRB intake manifold. I am planning on getting an rbc , 70mm TB and a 3 inch catback very soon. I know this will increase airflow and allow me to make power above 7400 rpm, and therefore i am positive that i will max these injectors out.
Apparently if the fuel pressure is increased to 70 psi, the RDX injectors will flow up to 550cc, and this is more than enough for my setup. I DO NOT want to replace my injectors as i just got them 2 months ago.
I would appreciate if anyone can give me technical info on how to do this reliably, as this seems like my best option. Thank you in advance
