DIY: DC5R Rear wiper delete
    Hello CITR members,
    As easy as this DIY is and couple tutorials around on CLUBRSX thought i'd make one for Club ITR, so here we go. This also applied to EP3's as its quite similar.
    Tools Needed :
    Phillips head screw driver
    10mm socket
    12mm socket
    Adjustable spanner/wrench.
    Wiper blank plug/grommet CLICK HERE
    Black silicone adhesive sealant (optional)
    Estimated job time :
    15 - 30 mins
    So here we have the complete standard rear wiper
    Remove cap and remove this nut, (12mm)
    Remove this plastic cover by simply pulling off.
    Remove this nut and thats done for the outside.
    Remove the phillips head screw holding this down
    Not pictured but also remove the single phillips head that is located inside the handle (where you pull the hatch down when closing)
    Remove 2 side panels and main cover and should have something like this
    unplug this and undo the 3 10mm bolts
    Once thats done, simply remove the wiper motor and you will have something like this
    Remove the top metal plate and the oem grommet
    You will have a hole in your window!! Clean the surface for a good seal.
    Plug in your wiper grommet/blank
    Now with mine it fit well but I could easily pull it out with abit of twisting from the outside, so I got my self some of this (purchasable at your local supercheap)
    Neatly seal the grommet from the inside, this will insure no leaking and a good fit. Like i said this step is optional but I do recommend this step.
    Now before putting the plastics all on, close your boot, shoot water the grommet/blank and around it, make sure there is no leaks (give the sealant time to heal and bond)
    once you are happy you can put everything back together and enjoy the end results of clean looking window/rear end!
    So hopefully this was helpful to members. Quite easy job and pretty much the same principal applies to EP3's!
    Wiper motor and arm weighed in at just over 1.2kg, easy weight save yo!
    Thanks,
    Phil
    WSID : TBA
    Wakefield : 1:10.1
    Flippit Photography
    Smooth As Detailing
    Incar Racing
    Nice.. How much weight saving did you achieve??
      Wiper motor and arm weighed in at just over 1.2KG
      WSID : TBA
      Wakefield : 1:10.1
      Flippit Photography
      Smooth As Detailing
      Incar Racing
        This is something i couldnt do,i go crazy when my back windscreen is dirty or wet..i need that wiper more then anything! dunno how people can delete it =/
          Nice post man. I wasn't bothered to seal my plug with anything but no water gets in anyways!
            Thats why I use rain-x and a similar product on the rear and front windscreen. Once you get going and wind hits the windows the water literally slides off. Doesn't bother me that much
            Thanks bro! Yeah it is probably fine without sealing it but for piece of mind i just did it anyway!
            WSID : TBA
            Wakefield : 1:10.1
            Flippit Photography
            Smooth As Detailing
            Incar Racing
              Nice job! Regarding the sealant though, it would make it harder to reverse and put the motor back in wouldn't it?
                Correct, but nothing a hairdryer, scraper and elbow grease can't get off.
                I personally don't intend on putting the wiper back on so does not bother me. But if I do its no big hassle
                WSID : TBA
                Wakefield : 1:10.1
                Flippit Photography
                Smooth As Detailing
                Incar Racing
                  make one for front wipers =D
                    for the ep3s, a hacksaw is crucial ahahah. It looks like your arms came off quite easy ay?
                    Instagram: @ictorv2 & @00zaku
                      Haha dont tempt me :P
                      Sent from my Galaxy S2 using fapatalk
                      WSID : TBA
                      Wakefield : 1:10.1
                      Flippit Photography
                      Smooth As Detailing
                      Incar Racing
                        LOL seized and shiet! Nah mine came straight off haha so easy compared to yours....which ddidn't come off at all!
                        WSID : TBA
                        Wakefield : 1:10.1
                        Flippit Photography
                        Smooth As Detailing
                        Incar Racing
                          I normally use a wash & wax shampoo for the car and it cleans the windscreens really nicely and allows water to just bead and slide off, in normal raining conditions, sometimes I don't even use the wipers LOL
                            LOL i just dont drive in the rain.. lol
                              Great stuff mate
                              I've had my rear wiper for nearly a year now, don't miss it!
