Hey all,
I started instaling my front camber bolts last night.
Top bolt was fine and net me negitive camber. However! the bottom bolt seems to be my issue.
If i use the bolt the same way i installed the top one, i correct the neg camber. Meaning the bolt will produce positive camber. (as per instructions)
Now the bolt washer needs to face opposite from top bolt to net Neg camber.
The washer tab handle does not fit facing that way due to the strut design.
I tried last night with the washer as far as i could go facing towards the fender. But this just corrected the neg camber i had on the top bolt.
Any help or advice would be a big help as I was pretty frustated late last night.
