Are HAMP oil filter's genuine Honda?? They say there OEM but they are green and the ones ive brought from honda are blue.. And they say hamp not honda on them.. Could some one please clarify.. As im looking at buying in bulk from jdm concept.. " http://www.jdmconcept.com.au/index.p...detail&cid=186 " And wanted to make sure there alright!
Oil filters
Oil filters
So is hamp any good?? That link has alot of conflicting veiws. Also were you get your hands on the k&N oil filter's?? and ruff price??sigpic
Also.. One thing tinkerbell. Was just looking at K&Ns page.. They say we need the HP-1004 not the HP-1010.. Is there a reason for the difference??sigpic
that's why i posted it!Originally posted by Karl View PostSo is hamp any good?? That link has alot of conflicting veiws.
i get them from the US, for about $13ea...Also were you get your hands on the k&N oil filter's?? and ruff price??
the 1010 is for K20A etc, it is thinner and provides better oil pressure than the old fat style...Is there a reason for the difference??... retired/
So what should i run on my B18c7??? the 1010 or the 1004..sigpic
LOL well my understanding is that all honda's run the same oil filter. But if this is the case why do they suggest differ filter for differ models... If i recall right your running a vtir.. So id take it that there fine on the B18.. Also what site you get them from.. I rang Repco.. $30 for the filter plus $10 as they will need to order in.. And ebay from Uk is $15.36 Au..sigpic
Incorrect. Bseries and Kseries have different filters. The thread is that same the screws them in(Some other car manufacturers have different thread size on different engines) but the dimensions of the actual filter is different.Originally posted by Karl View PostLOL well my understanding is that all honda's run the same oil filter.
The B series filter is shorter and wider diameter and the K series is longer but smaller diameter. I believe even Ichishima-san from spoon said in the Best Motoring DVD to use the k series filter on the B engine to get better oil pressure.
I've always used just normal Honda filters, i've tracked my car many times and had no problems. I have noticed recently the blue colour they use on the filters has changed and they they are now made in Thailand not Japan.
Sweet thanks 4 the help guys!!!sigpic
Originally posted by tinkerbell View Postthe 1010 is for K20A etc, it is thinner and provides better oil pressure than the old fat style...Regarding your and tinker's posts, I have always wondered how a smaller filter gives more oil pressure? A larger filter media as in the old B series filters and the PCX filter that is still made for the S2000 should, all else being equal, give a lower pressure drop over the filter media. I'm sure either is fine, and I have always used the smaller filter, but I am just curious.Originally posted by TOU93 View PostIncorrect. Bseries and Kseries have different filters. The thread is that same the screws them in(Some other car manufacturers have different thread size on different engines) but the dimensions of the actual filter is different.
That is a poor generalisation, S600s don't run the same oil filterOriginally posted by Karl View PostLOL well my understanding is that all honda's run the same oil filter. But if this is the case why do they suggest differ filter for differ models... If i recall right your running a vtir.. So id take it that there fine on the B18.. Also what site you get them from.. I rang Repco.. $30 for the filter plus $10 as they will need to order in.. And ebay from Uk is $15.36 Au..
Personally I don't know. I only have a water temp and oil temp gauge so I can't personally talk about pressure. I have only gone off what I have read/heard.Originally posted by ChargeR View PostRegarding your and tinker's posts, I have always wondered how a smaller filter gives more oil pressure? A larger filter media as in the old B series filters and the PCX filter that is still made for the S2000 should, all else being equal, give a lower pressure drop over the filter media. I'm sure either is fine, and I have always used the smaller filter, but I am just curious.
LOL i no this is abit of topic.. But i brought a cluster that holds to gauges.. Already brought water temp.. Should i get oil temp or pressure for the other spot??sigpic
