I read some were that the DC2R has a oil cooler from stock.. Is this true.. If so were is it located.. Does it work efficiently or do poeple upgrand them.. Thanks guys!!
DC2R oil cooler
DC2R oil cooler
Yes, it is a water to oil heat exchanger, it is on the back of the block between the block and the oil filter and has a couple of coolant hoses coming out of it. It acts to both pre-heat the oil when the engine is warming up and to cool the oil when the oil temperature exceeds the coolant temperature.
I like it because it is a simple robust design, and for light track use and performance street use it will be adequate. HERE is a post by Evatec (
) regarding the cooler and the effect he saw by upgrading just the radiator to maintain coolant temperatures at a lower level. The cooling system on my Integra is stock but if I upgraded something it would be the radiator to maintain a better coolant temperature and let the oil look after itself.
Thanks guys..Does any one have a picture??sigpic
Stock oil/water exchanger is sufficient. Dont bother with oil cooler, cold oil temps will do more harm to the engine.BYP Racing & Developments
Ok so i had a look today and am suprsied i never noticed it during oil changes.. but one thing i also did just notcie.. Imbetween the oil coller and the filter is a other small plate.. It has no ports.. Any idea'ssigpic
Could be some kind of aftermarket sandwich plate for sensors? Take a pic.BYP Racing & Developments
Yer i will next time im under.. But it has no ports.. So i dunno??sigpic
lol
