Asking about performance radiators... I'm interested in the Koyo R2028.. Does any one no if it fits the stock fan's?? And is a direct fit with out modification?? Or any other brands you guys recommend ?? Thanks guys!!
Performance Radiator
Thanks mate! Where you get the slim lines fan's from?? I looked on the net.. There so many and they look crap!!Last edited by Karl; 02-09-11, 11:56 AM.sigpic
Very nice.. It wont over heat when stationary with one fan??? Also i have header's so i think there's more room as there no cover!!Attached Filessigpic
Sweet.. Direct fit.. No modding done to get it in.. Also nice engine bay.. So clean!!!!!sigpic
+1 for davies craig! i have them in my DC2 2 x 12" slimline fans, definately quiter than stock fans and cools down quickly. my water temp is at 98 when the fans kick on and within 10-15 secs in really drops down to 90. (this is sitting at the lights)Originally posted by DLO01 View PostDavies Craig is a good brand. You can order through super cheap.
Sweet thanks guyssigpic
Yer im in syd... One thing did our R have the DENSO or SHOWA radiator's... I have a universal one fitted in my car.. I have a 2001 dc2R ifs that differ any thingsigpic
Some are running Showa and some are running Denso. Showa and Denso radiators are running different fansOriginally posted by Karl View PostYer im in syd... One thing did our R have the DENSO or SHOWA radiator's... I have a universal one fitted in my car.. I have a 2001 dc2R ifs that differ any thingJDMyard Pty Ltd / Hardrace AU
25 / 317-321 Woodpark Rd , Smithfield , NSW 2164. Contact : 97572365
Email : yonas@jdmyard.com
Is there a way to tell off the fan's then??sigpic
doesn't matter if you are running davies craig slimline fans, they are universal fit anyway. on my koyo 53mm radiator, stock fans can't fit on.Originally posted by Karl View PostIs there a way to tell off the fan's then??
You can either custom build your own bracket or you can use the method they advise (bolts through the radiator between the fins) personally i was worried about the bolts moving each time the fans kicked on and everntually cracking the fins and extreme cases causing a leak. Probably won't ever happen but just being anal and over protective of my new shiny radiator.
