Hi guys,
As some of you might've noticed I've recently bought a DC2R, and I just have a few questions in mind just to make sure everything is okay. Before I go on with the question just a heads up I have close to zero mechanical background everything I know to date is from reading all over the place on these forums.
My temperature gauge is past the beginning line while the car is off (hope that's not too bad a sign, seems pretty normal to me if over time it's just leaned abit too much to that side).
But is it completely fine for my car to be running somewhat pretty cool? It's been really cold in Melbourne the past couple days as well so that's not too surprising if that plays a role.
The needle moves up accordingly after about 5 minutes, at what seems to be halfway between 0 and the MIDDLE, I can feel good heat coming through the vents, and after some spirited driving it gets closer to the middle. But I've noticed that sometimes, turning on the heater to 2-3, fairly warm, hot air comes through and my temp needle drops by a notch or half a notch?
The dropping happens when I go into a casual light cruise for over 5-10 minutes as well.
So if anyone can tell me if this is normal, that I'm relieving the engine of some of the heat when I turn on the heater? or anything. Thanks
I'll definitely try my hardest to be at the Melbourne meetup on the 10th looking to get heaps of input and pointers and to meet you guys, cheers.
Khang
P.S. I've tried searching the forums beforehand but maybe I used incorrect methods.
Khang
