My brake pads finally need replacing. Apparently there is a tiny bit left before the wear indicator on the rear and a little more on the fronts.
Car has done 182,800km so i would love to get to 200,000km.. would be a great milestone :P
anyway, the dealer asked for $330 to change the rears and machine the rear discs.. seemed like a lot so i told them not to do it. i can easily change my brake pads myself. Honda pads are $160 for rears, $230 for fronts btw.
I have ferodo DS2500 pads sitting in my garage that i swap in for track days that are probably 10% used.
firstly, do the discs really need to be machined generally? i am not getting any shuddering at the moment. What does it generally cost to get done?
Would i generally expect the disks to last another 200k km with oem pads after they were machined?
How much faster would i wear the disks if i put the ferodos on instead of oems? (I currently very seldom use them so might be nice to use them up)
what do oem disks cost if i do wear them out? compared to aftermarket ones? Is replacing the disks a good mod? Its unsprung weight so maybe lighter ones? slotted?
