Calculating your mod cost
This topic is closed.
    Whos done a sum up of their mods + labour recently and looked like something along the lines of below:
    yeh, i have a running spreadsheet. by the time i'm done i'll have spent about $20k.
    almost JDM spec, y0!
      I've spent only 2 Gran so far, Only on basic mods.
      Hoping to reach the 10 Gran mark by the end of this year.
        i really dont want to know how much i have spent lol...
        i will probly die
        *EDIT*
        just did a rough calculation, around $9000 O_O
          I've spent...like...
          $6 on air-freshener
          $20 on a 2007 street directory
          $11 on a container
          $3 on a bucket
          :P
            you have 8k to spend in 2 months .. so lucky
            We should all buy a porsche and keep it stock..
              i spent about 15k ontop of the purchase price of my dc2 purely on work and mods (and a lot of DIYing). that 15k does not include things like minor services, oils, regos, etc. she will be missed.
              when do we hit v-attack | www.eightsided.com
                TYRES
                D01J tyres
                fit and balance and align
                new T1R tyres
                wheel alignment
                new R888 tyres
                wheels alignment
                SERVICING
                new thermostat
                Tectaloy coolant
                Iridium spark plugs
                Castrol Formula R Blue
                Z79A filter
                brake fluid
                Front wheel bearing
                wheel bearing fitting
                wheel hub replaced
                Castrol Syntrax gearbox oil
                coolant hose
                coolant
                new fuel filter & hose
                Mobil 1
                filter oil Ryco
                Mobil 1 5W-50
                Valvoline oil filter
                PERFORMANCE MODS
                Cusco coil-overs
                Type R brakes
                Plot Braided Lines
                HKS Cat back exhaust
                whiteline rear tie bar
                whiteline rear swaybar
                used ENDLESS brake pads
                Motul RBF600 brake fluid
                JDM 4-1 extractors
                2.5in Cat
                Type R front chassis brace
                Cusco master cylinder brace
                Cusco front strut brace
                NEW Whiteline QR rear brace
                Cusco 6k springs
                K&N air filter
                Walbro fuel pump
                catchcan fittings
                surge tank fittings and spacer
                surge tank fittings
                oil gauge fittings
                oil pressure adaptor fittings
                weld in temp fitting
                ES engine mount inserts
                ES LCA bushes
                ES RTA bushes
                VTEC line dash 6
                oil cooler
                speedflow fittings
                Power FC
                Dyno Tune
                DS2500 brake pads
                eBay intake
                B20VTEC ENGINE
                B20B8 block
                B16A Head
                B16A2 water pump
                ARP head studs
                ARP rod bolts
                oil line and fittings
                Honda OEM parts
                VRS kit from Zi
                rebuild head
                Mobil1
                Tectaloy
                oil filter
                dremel for pistons reliefs
                tow to asquith
                machine flywheel
                heater hose + clamps
                Speedflow PCV hose 10mm
                PVC vent hose 13mm
                fuel rail fittings (8mm 1/8bsp barb)
                fuel hose 8mm + clamps
                vacuum hose 3mm
                PCV catch can
                CTR camshafts
                CTR springs
                ITR intake manifold
                Toda 4.1kg flywheel
                Sard FPR + gauge
                Apexi V-AFC
                Toda cam gears
                Exedy clutch
                tuning
                MISCELLANEOUS PARTS
                Kenko car cover
                Phillips HB4 bulbs
                Lambs wool car wash mitt
                Mothers car care
                wiper blades
                used rear engine mount
                used clutch MC
                brake light bulbs
                battery tie down
                ITR front lip
                used electric aerial
                ITR floor mats
                used digital clock
                ITR door trims
                clear blinkers
                new locknuts
                Kenco dry detailing cloth
                ex. Manifold bracket
                Maguire's clay bar
                Autometer gauge adaptor
                header tape
                mag drain plug
                new lock nuts
                water gauge
                bearing press - 6T
                water adaptor
                TB gasket, TB screw, NH592P
                paint, buffing pads,
                MityVac
                well, that is my list, abt 15 grand over 2 years,
                includign one blown engine replaced at about $6000, includes $2500 of tyres, the rest is performance mods
                only spent $700 on "servicing"
                  <snip>
                    i think some would agree that it would be better NOT to know how much we've spent
                    btw, nice list tink
                      Maybe that's why the blown engine
                      For me, i think i spent around 13K on mods this year.
                      Vertex Bodykit
                      HKS FMIC
                      Pivot Oil Temp/Pressure Gauges
                      Cusco Rear Strut Bar
                      Tein Flex Coilover
                      Trust 16 row Oil Cooler Kit
                      Exedy Lighten Flywheel
                      S15 turbo upgrade
                      HPI Engine Damper
                      HKS Dump Pipe
                      HKS Front Pipe
                      Some little jap brand on my Castor Rod & Tension Rod
                      man.....all these doesn't include servicing, tyre changing and etc......
                      For all ralliart colt owners & lovers, i'm please to announce that the ralliart colt forum is finally online and working. Please come and support the site. http://www.rcolt.com
                        no, that was due to running 10W-30 oil on the race circuit with no oil cooler
                          I have done bugger all mods on my car, and I am already too scared to add it up.
                            that a crazy listing tinker.. damn.. how did u remember everyhting.
                              I have spent 1300 on pendders springs an koni ajustables front shocks and i am NOT HAPPY. Got a ride that is just a bit better than terrible an spent $400 of MY MONEY on warranty of ONE koni shock not to mention 1 week with out my car. Koni has crap warranty remeber that.
                              End of rant
                              oh an i have also K&N airfilter
                              F/S: VTI-R Civic
