Guy, if you are not already aware, I blew my engine last Sunday at Oran Park.
i was going down the main straight, as i backed off to brake, a rod went through the block.
Today I pulled the engine out and tore it down. It appears to have been a rod bolt failure.
1st pic - engine out of the car
2nd pic - intake side of the block, the main cap which was in pretty good condition considering is wedged in the hole
3rd pic - Things I found in the sump
4th pic - OUCH, the crank doesn’t look too healthy
5th pic - Beaten up block with a few holes in it. You can see the base of the Toda piston with the ripped out gungen pin and half the rod sitting in it.
