remove EVERYTHING that dosn't "power" the car. (aircon, powersteering... and if your super keen, ABS)
move the battery to the boot, or relocate it to another section, using a smaller item.
all wires tucked into fenders.
if its a half assed job (like above) it does look dodgy, cause you can see all the holes... for where everything was ment to go. i have seen a few that where done VERY well. ALL holes covered up, completly flat firewall etc etc
its more than just "moving" the wires, alot of time and custom work is involved if you want a pro job... including work on the bay itself, not just the components within....
I wonder how much an electrician will charge you when u have elctrical problems... ahahah they would have to like remove you guards or come from below ahah..
hahah and make sure if you are attempting a wire tuck to also line the cables up to the top and not sit on the wheel inner plastic guards to prevent water soaking........
