so hey guys, just wanted to ask would the ep3r seat fit into a dc5r? im a newbie at this stuff and just a question of curiousity. and also would like to ask is it just a straight swap? or would i need the rails aswell for the seating. just thinking of swaping the drivers seat so i could perserve the recaro drivers side seat.
Would Honda EP3R seats fit in a DC5R???
This topic is closed.
Originally posted by Perry View PostFrom memory EP3 recaro's will fit into dc5r with dc5r rails, but will let others to confirm as well.Originally posted by PENUT View PostPretty sure it will bolt straight onto your dc5r railsOriginally posted by Hau View PostI know the dc5r recaros wont fit ep3 seat rails as my mate was looking to swap but it was too much work to make them fit. I could be wrong. Test fitting would be your best bet
From memory most sr series seats are interchangable going by using after market rails such as bride or recaro the mounting holes are the same. I might be in the process to do the same thing will let you know if I do it before you. But try it anyways.ek9-->ED civic--> eg--> S2K-->JDM DC2R-->EP3
Originally posted by Hau View PostTake out the passenger side remove the rail of the seat and take the rail to the seller and try to see if the holes line upOriginally posted by Perry View PostFrom memory most sr series seats are interchangable going by using after market rails such as bride or recaro the mounting holes are the same. I might be in the process to do the same thing will let you know if I do it before you. But try it anyways.Originally posted by dnapol View PostMy dc5 sr4s had different mount holes on the base to ep3 rails so it was impossible to fit them, I assume its the same putting ep3 seats in a dc5
thanks guys for the advice, by the soudns of it most like im gonna get the drivers side seat and the rails aswell...
Originally posted by mountfranklin View Postreallyyyyyyyyyyyyyy??? do you know who he is? i would like to have a chat with him about the seat swapping his done!
