Hey guys, I'm looking to rebuild my dc2r engine. My mechanic has given me a price for the labour but I have to supplies all the parts. Does anyone know where I could get everything needed for an OEM built apart from Honda. If anyone knows any shops of a different brand name that you have used before and feedback on it would be great too thanks.
DC2R Engine Rebuild Help!!!
Depending on what you have planned for your rebuild will determine what parts will be required. I can supply OEM & aftermarket pistons, rods, rings, bearings etc but I will need bearing & bore measurements before anything can be orderedSleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
your mech needs to tell you what bearings to buyOriginally posted by lil_sprinter View PostHey guys, I'm looking to rebuild my dc2r engine. My mechanic has given me a price for the labour but I have to supplies all the parts. Does anyone know where I could get everything needed for an OEM built apart from Honda. If anyone knows any shops of a different brand name that you have used before and feedback on it would be great too thanks.
he should be measuring up everything first before telling you to buy parts.
Sorry if I was unclear, the motor is getting old 205000km and blowing a bit of smoke on vtec and burning alot of oil. I'm planning to hit the track so want a reliable motor. I'm not a mechanic so don't know much about engine rebuilt lol. All I want is good quality japanese parts for the rebuilt.
Quality Japanese parts come at a price. High quality American parts are the way to go. As Oscar has said, you will need measurements for main & rod bearings, along with bore measurements before you can order anything, as you may need to go to .5 or 1mm oversize pistons and .25 or .5 oversize bearingsSleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
Just one more quick question, If i decide/need to go 81.5mm over size piston then do I need to go to .5mm bearing as well? Sorry if this is a noob question.Originally posted by sleepingperformance View PostQuality Japanese parts come at a price. High quality American parts are the way to go. As Oscar has said, you will need measurements for main & rod bearings, along with bore measurements before you can order anything, as you may need to go to .5 or 1mm oversize pistons and .25 or .5 oversize bearings
You will need to go to .25 or .5 oversize bearings anyway as you will need to linish the crankSleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
but to clarify,
the size of over-size pistons have no direct relationship to the size of over-sized bearings required for the rebuild.
both requirements are directly dependent on the amount of damage that you are trying to fix to the cylinder bores and crankshaft journals respectively...
and lil_sprinter - since you have not properly diagnosed your engine - you still dont know if it is the head that is causing the smoke or the block that is causing the smoke...
if you are rebuilding the bottom-end - you also need to factor in rebuilding the head.... retired/
