I bought some Hasports... anyone able to help me with the rear mount?
DC5 - How to replace rear engine mount
Originally posted by DanR View PostYou need to drop the down pipe to be able to get to the rear mount. Use a loooong extension with from memory a 12mm socket on the end. If you have trouble getting the bolt to line up through the middle of the mount raise the jack/loosen the other mounts.Last edited by felixR; 18-04-13, 11:12 PM.sigpic
Originally posted by Hau View PostIve done my engines mounts before, I didnt have to drop the down pipe or any pipe to get access to the rear mounts. Just jack up your car. You will need to put the car on jack stands. Use the car jack with something like a yellow page book and raise the jack up slowly to support the engine while you take on out at a time. I found the rear mount to be quite easy. The front mount was a bit of a pain but got there in the end. Just need some elbow grease to loosen the bolts. A friend or two will come in handy.Last edited by felixR; 18-04-13, 11:13 PM.
