I recently had some Tein Coilovers fitted to my DC5S by a not to be named shop who managed to only adjust one side rear hardrace rear camber arms leavin the other side unadjusted and with massive negative camber. Not only that but they cross threaded some of my bolts and neglected to tell me...
I took my DC5 to Chris at centreline suspension in Thomastown, Melbourne and have nothing but good things to say about the quality of their workmanship. They managed to tap the thread which was ruined by a cross threaded bolt and replaced the old one with a new bolt. the other shop also managed to cross thread the hardrace camber arm itself... (perhapse why it was left unadjusted) which Chris was able to fix.
As for the alignment itself I couldn't be happier with the resulting handling of the car. Centreline are very experienced with setting up cars for track work as well as your daily driver. Alignments at centreline are not among the cheaper options, but I truly believe that if you want a custom job and the job done right the first time then I can not recommend these guys enough. My only regret is that I let the first shop install the suspension instead of these guys. Will be coming back for a track setup at some stage.
http://www.centrelinesuspension.com.au/
