JDM DC2 Integra Type R 98 Spec
Championship White
Purchased this in July 2014 with the idea of using this as a daily so I keep the K's down on my Golf MK5 R32. Always wanted a 98 Spec Type R, anyways, I started tinkering away as you do, and started cleaning the car like a mad man. Pulled all the trims back and cleaned everywhere; literally. Then came the problems, RUST, LEAKS from the tailights (common I know) and a randomly bent front left suspension arm which left it with a permanent 3 degrees of camber on the front left whilst all the otherside has 1.5 degrees camber. So the issues with the car started to mount up which in turn made me have buyers remorse! So then came the bright idea to turn return this to its former glory with a bit of flare. Decided to continue on the path of building a daily driven / track attack car / garage queen. So far this is what I've done! I'll make sure to keep it updated as the progress comes along
Engine/Drivetrain
- Simota Intake (can't wait to get rid of this)
- Second Generation Mugen Intake (undergoing repairs to carbon box)
- Innovative Billet Engine Mounts (85a - Grey - Race)
- Skunk2 Alpha radiator
- PLM Tri Y Headers
- Mandrel Bend 2.25 exhaust with Vibrant Performance Hi-Flow Cat to Matte Black Vibrant Performance Exhaust
Suspension/Handling/Braking
- Skunk2 Pro C Coilovers
- Skunk2 Camber kit front and rear
- Znoelli DDS rotors (front and rear)
- Endless N35S pads (front)
- Hardrace bushings
Interior
- Mugen Pedal Kit
- Broadway Rear View Mirror 270mm
- Ulitmate LEDS Interior 24 LED Panel
- PLM X Bar
- Battery Box (yet to relocate)
- RaceTech 4 Point Harness
- K-Tuned Pro-Circuit B Series Shifter
- Type R weight gear knob
Exterior
- Type R Sticker Set
- Rolled guards
- Ultimate LEDS Reverse Plasma LED Bulb
- Ultimate LEDS Licence Plate LED Bulb
- 16x7 et50 Stock 98 Spec ITR wheels 205/40/16 Bridgestone Potenza RE002
- 17x8 et35 Desmond Regamaster 235/40/17 Nitto NT05 Semi Slick (SOLD)
- 17x7.5 et42 Advan RG (Gold) 225/45/17 Nitto NT01 Semi Slick
- Password:JDM Carbon Gurney Flap (not attached yet)
- Password:JDM Carbon Intake Duct (not attached yet)
- HC Racing Carbon Lip - M style (not attached yet)
- Speedhunter/Takata Tow strap (not attached yet)
Misc.
- Rust Repair boot hinges
- Tail Light Leak Repair - new foam gaskets
- HeadLight Restoration
- Paint Correction - first stage
- Stripped Rear Interior
- A/C Removed
Things to do in the next couple of months
- Re-paint guards/touch up
- Attach all the carbon pieces
- RaceTech Bucket Seat
- Install Mugen Intake once it's been repaired
Parts to hunt down
- Spoon Carbon Mirrors
- Fiberglass Race Bonnet + AEROCATCH latches
- Motul Brake Fluid
- Braided Brake Lines
- Spoon Sports Monocoque Callipers
- Maybe put a headunit in and speakers
Future Misc/parts/things to do
- Baffled sump
- Oil Temp Gauge
- Shifter light
- ECU Tune
Championship White
Engine/Drivetrain
- PLM Tri Y Headers
- Hardrace bushings
- Front Lower Control Arms
- Rear Trailing Arms Bushes
- Front and Rear Sway Bar D Bushes and Endings
- End Links
- Shifter Bushes
- End Links
- Shifter Bushes
Interior
- Mugen Pedal Kit
- PLM X Bar
Exterior
- Rolled guards
Misc.
- A/C Removed
Parts to hunt down
- Motul Brake Fluid
- Baffled sump
- Oil Temp Gauge
- Shifter light
- ECU Tune
