FD Sports Sedan - Mazda RX7 with Honda K24 turbo
    Hi All,
    We are building a new car to run in the Kerrick national Sports Sedan series.
    I used to run a Fiat sports sedan and then a Calibra with a v6 twin turbo but my dream had always been
    to run a 4 cylinder turbo car and to try and win the title against the big 6L v8's.... so here i am spending
    all my time and money!
    Basic's
    The car uses a series 6 Mazda Rx7 FD body shell. It is wider by 100mm both sides than standard. The shell
    including doors, roof, sills, front and rear clips etc weighs in at only 65kgs. The top of the roof at its
    finished sitting height is just over a metre off the ground.
    The chassis is a tube frame chassis utilizing push rod suspension. We have designed the chassis in cad and
    have put it through fea analysis. The results in cad are quite good, it will be interesting to see how they
    compare to the real world tests we will perform. The chassis around the driver has been designed a little
    heavy as i wanted to make sure im safe. The engine sits as far back as we could get it. I can reach out
    from my seat and place my fingers in the back of the rocker cover.
    Now for the engine which is what i guess you guys will care most about
    we decided to use is the Honda K24. We will be turbocharging the engine and power plans are
    around 700 RELIABLE horsepower. The engine needs to be run hard for 25-30 mins at a time which is our
    race lengths so there will be no 1000bhp time attack style turbo's going on it as it would blow up quite quickly
    having to run those kinds of durations.
    We are doing 2 engine's, the first is a little bit 'cheaper' option so that we can run it and test it and if we push the
    limit too far it wont be such a bad cost to deal with. In saying that it is still a very strong engine
    Honda K24 block with oil squirters
    Sleeved and deck has been closed and o-rings
    The K20 Head has been ported and machined to suit the k24 with supertech inconel valves, supertech springs, retainers
    new bronze guides, machined valve locks and all new seals etc
    Billet camshafts
    Toda adjustable cam gear on exhaust
    Cosworth head gasket
    Mahle forged piston
    Manley Rods
    AC bearings
    L19 head studs
    Balanced and treated standard crank
    The driveline consists of a Hewland SL 6 speed sequential transaxle. It is rated for 600ft/lbs of endurance racing
    and allows us to quite quickly change ratio's at the track if need be.
    Brakes are 375mm rotors at the front with 6 pot AP calipers, the rear is 343mm rotors with 4 pot performance friction
    calipers. We are using a tilton pedal set.
    We are currently in the process of machining the suspension pieces and also putting the engine together.... ALOT of work ahead
    https://www.facebook.com/Fdsportssedan16?fref=ts
    Welcome to ClubITR. First off, WOW! This is absolutely huge!
    I'm sure many of us are very intrigued with your build, especially some of the RX7 owners on here. Looking at the CAD picture, it's really interesting to see how the engine mounts up to the transmission.
    Looking forward to the updates! Thanks for sharing this with us.
      This certainly looks like it could be the BEST build I've ever seen. Eager to see updates, keep up the good work!
      1995 Honda Civic EG (K20)
      RHCP
      F1 Nut
        Amazing build, thanks for sharing this with us. Will be following this one very closely!
          Thanks guys appreciate the comments
          butter there is about 500mm between the engine and the gearbox (we havent finalised engine position yet)
          Off the front of the transmission there is a spline which has a flange that bolts to it that then has a cv type joint.
          We then will have a shaft from the cv joint to anoher cv joint which is bolted to the crankshaft. Although we are
          still contemplating uni joints etc depending on our end angle.
          The flywheel and clutch is built inside that front housing on the transaxle so the tailshaft will spin at engine speed.
          this picture was when we just had a dummy piece of steel in there to get an idea on how close i could move my seat
          to the centre of the car before being too close.
          the starter motor is also housed within the transaxle so i will be cutting the starter motor mounting point off the engine
          as it currently hits my knee.
            very nice work...
            looking forward to following this...
            me and my bro have done and use as a drift car on the track a K20a matched to a s2000 gear box, gt3076r in a s13 silvia...
            my sale thread 21.01.12
            CLICK & BUY AWAY
              I can't picture how you guys intend on making this work, as this is so crazy. (crazy good!)
              All I can see is an engine mounted next to your seat, and the intake manifold where the steering wheel would be. Then theres piping? intercooler? And and .. *my brain hurts* The amount of work put so far, and coming ahead is mind blogging.
              I'm guessing you guys are at this full time as apart of a workshop?
              Whats your ETA of this being completed?
                Coolbuild
                  just reading the sports sedans website, your build embodies the:
                  "The Sports Sedans category is one where freedom of expression is regarded as a legitimate means to an end - and that end is performance, and lots of it."
                  philosphy
                  http://www.sportssedans.com.au/index.php?page=technical
                    Haha its not as bad as it seem's.....i think
                    Yes we do have a problem with inlet manifold. We are going to use a skunk2 ultra race to start with. We have it ported to suit
                    our cylinder head. It will be heading over here with the cylinder head from the usa in a few weeks.
                    We may have to lean the engine over a little to help with steering wheel clearance. The bigger problem is actually the gear lever
                    as the downshifts may see my hand getting very close to the engine cover. All things yet to be finalised but it WILL all work out
                    i am sure of that.
                    No def not a full time shop thing, my father ran a mechanical workshop for 30 years and then when he shut it down we moved all
                    his stuff into my shed so alot of work goes on in there. The car is currently at his old apprentices workshop which is a roll cage
                    manufacturing place AGI engineering. Perfect for us as he has all the right tools and equipment for bending bars etc. The jig the car
                    has been made on has made it so that all the bar work is within .5 of a mm of where it should be. The chassis was welded in special
                    sequences to make sure it didnt 'pull' or warp during welding. This is important to make sure all the suspension points are in the right
                    position to begin with.
                    The build time has been blown way out lately because our category sports sedans is under going rule changes. This means we have
                    had to stop progress for months now waiting on the new rules as they will largely change the direction of a few things in the car.
                    It is still moving along just very slowly at the moment. Like i didnt need the real engine for a while as a dummy engine would suffice
                    but we have just done it now while waiting for other things.
                    ievaq8 sounds like a fun little machine, i cant see how people go past the honda engine. I did ALOT of research before deciding on
                    the engine for this car. originally it was going to be the mitsu 4g63 but after talking to some heavy hitters like the lead engineer
                    at cosworth and all the top time attack teams we found that they will never work unless you have a billet head and block. They
                    are good for short stints but once heat gets in them they are useless. We then went onto using a bmw engine out of the old m3's
                    / formula one cars and if the honda fails this is the engine we will revert to. Its just getting hard to get parts for them.
                    haha sports sedan philosphy is in my blood. no better category in oz that actually races door to door
                      Welcome, and thanks for sharing your build! Will be following closely.
                      Originally posted by MrBoost View Post
                      The starter motor is also housed within the transaxle so i will be cutting the starter motor mounting point off the engine
                      Probably the first time that's been an issue for someone with a K motor .
