Hi All,
I recently moved to a new city and as many of you know yourselves the main concern for any car nut without a car is what car to buy next!
I was initially just looking for a daily driver and after weighing up the cost and performance of a few cheap Japanese cars I purchased a Dc2 Vti-R (GSR) with 280000km's on the clock.
When I brought the car it was 100% stock and drove fine if a little loose and rattly. After driving the car for a few months I started researching modified Dc2's and Type Rs as you do. I originally intended to leave the car stock but after reading some of the great build threads on the web I convinced myself modifying the car was a good idea. The Dc2 Type R is touted as the "best handling FWD ever" and I wanted to experience the full potential of the Dc2 chassis.
Given the mileage of the car I wanted to refresh the essentials. I started by replacing the timing belt, water pump and rocker cover gasket.
The car then developed a squeal under brakes, I pulled the wheels off and sure enough both the front and rear rotors were heavily worn. I replaced the pads and rotors all around with cheap Repco replacements. Looking back now i wish i had researched brake pads a little more and gone with a more performance orientated set of pads.
I found a set of Tanabe Street sport struts for sale on ebay and decided they were the way to go because they reuse the factory top hats. As I intend to daily the car I want to keep the rubber damper bushes and spring isolator.
I ordered a combination of Mugen and Spoon hard durometer rubber top hat bushes and replaced the bushes in the UCA and LCA. I sourced a set of Hardrace adjustable camber and toe links for the rear, these let me set the toe and camber back to stock settings.
After a short time on the forums I noticed a large number of DC2's running the ASR subframe brace and 23mm Type R rear anti-roll bar, i picked up the bar from ebay and the brace from ASR. I was pleased with the quality of the ASR brace and found it straight forward to fit.
I brought the Type R wing and lip from ebay then had them painted by a local paint shop. I found the wheels for sale in Sydney and made the seller a cheeky offer which to my surprise he accepted. They are genuine Enkei Sport ES-Tarmacs 15x7 +40. The wheels feel light but i have yet to actually weigh them.
I'm really happy with the handling of the car now. I will continue to tweek the car here and there but my intention is to keep it on the road as much as possible.
Thanks
Grant
Thanks
Grant
