Tyre pressures mate. Most people run semi slicks at lower temps to allow for expansion under extreme heat. The problem is, on the road the tyres don't get hot enough.
i dont know about tyre pressure.. i just got the car 2 days ago..
shit more things wrong with it.. i need a new front bar.. cause the paints coming off.. it, previous owner hit a wall or something..
but im still trying to get used to it
stock B18c7
platinum spark plugs
k&N filter (stock box) i think it's running on a panel..
High flow cat
stock exhaust and headers
Not always. The tyres would need to be up to operating temperature to make the friction increase. This could be poorly setup suspension or just deflated tyres.
The owner hasn't driven the car without them so I'm not sure how he's gauging this.
Are they RT-615s? I think you need to check your tyre pressures first. For street use make sure they sit at around 38-40psi.
Front Wheel LSD does work your arms. Take it for a hard run in the hills, build your arms up. I still like to take a break after 30mins of hard twisties.
†ÎM؃Ÿ†Î†§
One To Pin (12PIN)
2002 DC5R
183.8kW of Normally Apirated 2150cc Toda Power at the Front Wheels
62.75s @ QR Sprints on DZ02G Semi's (stock engine)
124s @ Oran Park Superlap on Toyo R1R's (Toda Powered K21.5)
58.14s @ Lakeside Raceway on Dunlop Slicks (Toda Powered K21.5)
60.97s @ QR Clubman on DZ03G Semi's (Toda Powered K21.5)
59.03S @ QR Sprints on DZ03G Semi's (Toda Powered K21.5)
1:23.01S @ QR National on Dunlop Slicks (Toda Powered K21.5)
What kinda guy complains about there arms hurting after driving a car for 30 mins. Not even my pansy of a sister complains about it.
