Finding 1st gear hard
    Some times it wont go into 1st gear while stationery. If i put it in second ( do this with no problem's) it will go straight into 1st no problem after. Wondering why this is. Any help guy's
    What car do you have?
    Does this occur when its cold and warm or one or the other?
    Quote:
      Common issue with the selector in the DC2R boxes, sometimes you need to select R then 1 to get it in. Mind you, since my rebuild it hasn't been as much of an issue..
      I think its something to do with the actual selector motion.
        Did you rebuild yours with the carbon synchros from synchro tech?
          I have a integra type R 2001 DC2... Changing Gear box oil and clutch oil today.. Hoping for the best.. Using only honda oils 2.. No differ between cold or warm. Is it bad to go from five gear to neutral back into 1st at a set of light's after being stationery????
            hi Karl, welcome!
            your syntax is a little hard to follow, but if i read you correctly, it is not 'bad' to change gears when stationary as long as the clutch is in.
              DC2R -- Yes I did. Gearbox is 'quick' now. No signs of any crunch no matter RPM or speed of shift. I think the carbon helps 'brake' the shaft by around 30% more.
              I think they are also included in K series boxes from OEM now.
                LOL sorry was in a rush.. Did the gearbox oil and the clutch fluid... Fix the problem.. Runs gr8 no problem at all. And alot faster shift now.. Over the moon... Thanks guys
                  sounds like your car needs a bit of TLC then it will be singing the Type R song like it should
                    Yer running flat 6. 0-100... Singing her beautiful song..
