S2K antenna onto DC2-R
    hey all
    just wondering if the above subject is do-able, if so, what would it involve apart from the antenna...eg: is the wiring loom different, is the mounting different?
    cheers
    yeh some guy selln some on ozhonda for 50 bucks.
    LONDA
      which guy?
        Yep its do-able, theres a guide on team integra here
          you need more then the ariel mast for the conversion.
          you need this whole assembly
            ahh ok cool.
            so fill this fit straight on and is the loom the same.
            how much does this set up cost?
            thanks
              can i ask why you would want to change to s2k antenna?
                looks better and it doesnt always pick up good signal, my dads car picks up signal fine and so do my mates cars but this sometimes doesnt get the station or has that annoying static noise...
                  Theres an antenna called a shark antenna. Looks like the s2000 antenna. I've got that and it works perfectly fine, picks up the signals just as well and no more clickling sound from the stock aerial running up and down.
                  http://www.locustom.com/shark2_kit.htm
                    so was it easy to install....just pull out the stock one and screw this one in.....whats the wiring like for it?
                    good find
                      which guy?
                      his username is Zort on ozhonda. it works great and easy to install
                      LONDA
                        Originally posted by AKS200 View Post
                        so was it easy to install....just pull out the stock one and screw this one in.....what what the wiring like for it?
                        good find
                        Team integra has a write up on how to install it as mentioned earlier. It even tells you what cable to splice the booster into. So with pictures you cant go wrong.
                        I think Zort organised a group buy because he wanted one himself for cheaper, i dont think he sells them usually, just once off.
                          Zort was selling them a while back, i got mine off him, not sure if has anymore now. Best bet would be to PM him
                            MorningZ who did tutorials for both antennas reccomended to use the OEM antenna due to less installation fustrations.
                              I had the one that BrendanR has and I didn't even use the booster cable and it's fine
