FN2R Gearbox suited for Kswap?
    I have been advised that the K20 Gearbox from an FN2R is not suitable for a Kswap applications as they case have different mounts. Can someone please confirm this?
    hmmm I think I have the FN2R box in my car
    any way to check?
    Honda Integra DC2R natural aspired K20A
    2010 CAMS Supersprint (NSW) Type 3B champion |EC: 1:46.9280|WP: 1:07.694|Winton: 1:38.614
      Yeah i believe they are mounted differently
        mmm pretty sure they are the same gearbox casing
        you are changing the mount when you do a k-swap anyway
        might have to swap the shifter mechanism depending on what shifter box you are using
        and install the VSS gear on the diff, but AFAIK the mounting points on the case is the same.
          The outter casing is different. So no you cannot use em. But you can use the internals of the box i.e gears/finaldrive/LSD and etc.
            good to know, how different are they to the DC5/EP3 gearbox casings?
              now I know where Dedy's casing gone LOL
                Just the mounting point. The bel housing is the same i think.
                  Pm me about the stuff you want.
                    Can be used with the modification of a speed sensor or buy one of these to make the speedo work with out machining a hole for the speed sensor http://www.hybrid-racing.com/product...verter-sensor/
                    any way to check?
                    Your right about that nelson, you do!
                    Really?
                    DR HONDA K SERIES SPECIALIST
                    ALL MOTOR
                    dr.honda@live.com
