Hey there.
I put this thread up on Ozhonda, but didn't get much of a response. Was wondering if I might get a bit more help here.
"I have an EG with a b18cr. It currently runs with a p73 ecu.
Very soon, I plan on running Neptune. I understand that these only work on OBD1 ECU's.
Ontop on the Neptune RTP, OBD1 ecu, OBD2->OBD1 ECU AND OBD2->OBD1 Distributor harnesses, what other things are necessary to complete the conversion?
Would it be more beneficial to run an obd2 compatible ecu instead of all the extra headaches? or are there advantages in switching to obd1?
Thanks for the time. "
I have already found out that I don't need to worry about the dizzy being an obd2 (Thanks Toda)...
